Made up a manifold for the water temperature sensor for the SDS EFI system and installed it on the engine side of the thermostat. I then removed the gascolator and refitted with a better pipe sealant. I was getting the occasional drip when under pressure. All good now. I zeroed the elevator trim tab to coincide with the trim indicator.
