Installed the vent hood on the bottom of the cabin area. Shortened a lot of wires, reconnected and tied up. Drilled the r/s rad housing for the air sensor for the SDS system. Drilled the retaining holes for the muffler to exhaust pipe connection. I installed a special 3/8" flange bolt under the clamp. This permits the pipe and muffler to move independently and avoid weld cracking. I vacuumed out the entire cabin area, and under the floors. I reworked the plug for the air/fuel guage to include a wire to the efi system. This will permit richening/leaning the injectors in accordance with the air/fuel guage. Went flying with Charlie Brown in his Cherokee today. Lunch in Lindsay then back to work.
