Well I put off installing the rear window long enough. I got out the tinnerman washers, 6-32 screws, nuts and started the install. I guess I did the original layout pretty good. It all fit real nice. Carefully I put 1 in at a time. I left everything loose until finished. I am going to have to get 6x10-32 screws before I tighten everything up. My nose gear leg arrived back from the rework (Langair Machining). Maybe Monday I will remount the engine.
