I decided to install the strobe unit on the inside firewall by the passenger's feet. I match drilled the holes and bolted it in place. My friend Walt Hutchings helped me with the real bad bolt install. I then made a cable to directly ground it to the ground buss and attached it to the ground buss and the strobe unit. This should help eliminate any feedback to the other instruments. I'll keep my fingers crossed. I drilled the panel and installed a mini switch for passenger intercom isolation. You never know when you'll need to quiet things down...LOL !!
