Randalls Web Site
Date:  6-8-2009
Number of Hours:  3.90
Brief Description:  Installed prop
Comletely degreased all parts and then regreased with full synthetic hi-pressure grease. Attached hub to flange, installed the hall effect sensor, torqued and torque-painted the new nuts. Repacked the needle bearings, installed the bearing rings and bearings. Snugged up the prop attaching collars. Will torque to spec tomorrow.
