Randalls Web Site
RV9A
More wing work
Work on flap rod clearances. Adjusted flap motor to full retracted then set flaps to trailing position. Full extended to 32 degrees. Started to match up the fuel tank/fuselage brackets. Readjusted the angles for a better fit.
Final adjustments for flaps.
Full 32 degree landing config
RV9A Home
2423
Assembly
Calibration
Calibration and adju
Cowling
49
171
216
175
Finishing for first
Flight Testing
Instrument Panel
Landing gear
Redrive Swap
Taxi Testing
Testing
Transporting to hang
Wheel Fairings
250
Wiring
