Well, I finished the gear leg fairing hinge installations. I then cut the fairings to length. I placed the gear leg fairings in place, put the wheel fairings in place, and put the upper and lower intersection fairing on, and taped them all in place. I then fit then rough fit the upper fairings to the gear fairings. I taped the upper fairings in place for testing. The fairing is quite rigid. We'll see how it flies, and make necessary adjustments.
