Make 2 cutouts in the nose skin for the strut and jury strut attachments. put the nose skin in position and hold with clecos. Worked on the aileron and flap push tubes. Fitted the insert K329 in the push tube end. Drilled 2 1/8th holes and riveted with stainless steel rivet. Screwed the MM4 bearing. Stop nut is missing, I had to order some.
