Brief Description: right wing top skin & trail edge
Final riveting of the top skin. Also began to install the trail edge pieces. Wing tip position first then the root end position. Install a line between the external trail edge tip to check the distance for the middle one. Riveted the trail edge parts on the top.
Flip the wing over. Leveled and make sure to set the washout correctly. 13mm bloc at the trail edge spar (wing tip).
Lay down the bottom skin and cut the aileron and flap space. Trace all the lines for drilling.
