Began the day by setting the washout. Put a 13mm wood block under the trail edge spar at the wing tip rib, put some wood shingle under the rear spar to keep it straight.
Positionned the top skin and trim the edge and cut the aileron and flap opening. Mark the position of the ribs and stringers then trace the lines on the skin. Drilled and clecoed every 32mm along the stringers with the help of my friend Michel.
