I did the gap seal for the left wing only. Cut the .020 aluminium strip to 105mm wide, positionned and drilled holes at every 100mm. There is no indication about the distance between holes so I figure that 100mm would be OK.
I'll need 60 rivnuts for one side so I had to order some more.
