Lot of work done today. Positionned both wings near their final position. Get them leveled. Insert wing attachment into their respective plate. After checking the level and beeing sure everything is perfect, I drilled the front bracket on each wing and insert bolt. Then check the alignment with the string in front of the leading edge and measure diagonally from each exterior of the wings to the rear of the tail. When it is OK, I drilled the rear bracket.
After, I set the diedral of 100mm. Then I positionned and drilled the two strut end PM382 on the wing. Positionned temporarely the two struts end on the cabin plate and measure the distance to cut the struts. Insert the strut in their end connector and drilled PM382 on the cabin plate. Turn the struts to get some aerodynamics, then drilled 1 of the 3 holes on each end.
I also add a hook at the wing attachment point on the front strut, to secure the plane.
