Leaving the empennage gap seals behind I now started to tackle the more complicated and physically larger ones on the wings. I started with the flaps as I knew the Frise Ailerons were going to be a special challenge. Unlike the empennage gap seals the ones on the wings have two parts, the first mounts on the leading edge of the moving flight surface (i.e. the flap or the aileron) and the second mounts on the trailing edge of the wing and extends backwards to bridge the gap. My son and I installed the flap gap seals without difficulty as the manual instructions were good and no modifications of the supplied parts were required. OK Frise Ailerons, here we come..
