Roberts Savannah VGW Web Site
Date:  11-21-2010
Number of Hours:  1.50
Brief Description:  Panel
The kit came supplied with basic gugaes. The gugaes are various manufacturers (VDO, unnamed Chinese manufacture). One hole is empty in center for a radio. I need to take out the turn and slip for the encoder and find alternate placement for the ball.
There is very little guidance for wiring.The wiring diagram is very low quality and the none of the pre-prepared harnesses are identified - some are obvious, and others seem to fall into two categories - engine side or behind the engine. Clues abound, but there is no difinitive guidance except for the switches and MOST of the guages. There is no guidance for the low fuel indicating light and test button. There are auxilliary power cables available, more than I think I can use. Nicely prepared witring harnesses. As usual, the quality of parts is good, the instructions are lacking.
