Installing throttle cables required some minor modoifications. Because the angles would have been too sharp due to the placement of the airbox, it was necessary to go through the airbox. The air box has a rigid mount to the black portion of engine mount. The airbox was drilled and grommets installed to seal the holes. The passenger side cable routes through the entire length of the airbox. Its actually a clean install and means one less set of cables to tie down later.
