ROBERT'S WEB SITE
Stol 750
Prep & installed float, cut hole in the tank, put cork around tank, fit top skin cover. Installed side valve. Worked on Pito tube, drilled hole in rear channel, installed grommets & line for pito & static tubes
Stol 750 Home
373
Flaps
Inspection
Slats
