Decided to try loosinging the forward lift pin in the right wing to see if an adjustment in center-to-center spacing will avoid having to enlarge the lift bushings excessively. Stever will take a shot at it next week.
Pulled the flaperons out of the trailer and discussed trimming the molding flash and exposing the hinge stanchions.
The horizontal stab T-plate will not be ready today. Discussed trial fitting with Harold, assuming Jim will deliver the replacement plate next week.
Airbrake push rod -- Harold cut right wing push rod -- OOPS! -- cut to wrong side of tape marking location :-( Not a problem since 8mm rod end has enough adjustment range to accomodate the screwup. Decided to cut the left wing push rod to match.
