Continued fitting horizontal stabilizer to vertical stab. Drilled center hole in T-plate oversize to accomodate misplaced center "nutplate"/captive nut in horizontal stab spar. Decided to drill plate oversize then either bush it back down to 10mm, displaced, or fabricate a new T-plate using the original as a pattern.
Fit of T-plate and stabs now indicates the vertical stab holes are the right height, but that the bottom one must be opened up a bit to the right to level the horizonatl stab.
Bonded elevator trim lever base to fuselage. Need to get a longer 0.162-inch trim control rod.
