Finished trial fitup of MLG assembly (outside fuselage). Reduced diameter of sodket head screw for brake anti-torque link. Found socket head screws to secure wheel halves. Enlarged wheel half holes to permit wheel assembly.
Trimmed molding flash off rudder. Screw up! (Steve) cut off leading edge bond area -- will require overlaid lap of glass or carbon tape to reinforce.
Cut open rudder hinge ares in rudder. A VHF antenna _has_ been installed internally, and the rudder hinge fittings were preinstalled in the rudder.
