Aviation Graphics
RV-12
Wiring Harness Installation
Adding the Writing harness is at the same time⦠quick and easy, and very complex.
In order to install the TWO harnesses correctly, the Rudder Pedal assembly must be loosened and dropped down in order to route and secure them.
We turned the fuselage on it's side in order to get to the Rudder Pedal assembly, and to route the cables thru the lower center of the fuselage.
RV-12 Home
709
Finishing/Painting
Preparation
