Brief Description: Fuse assembly - 53 - Fuel system continued
Spent time rebending some lines that I was not happy with. I also modified the top cover to make clearance for the fittings coming off the Andair valve. Lots of distractions. It did take me three attempts before I was happy with the line that feeds the fuel flow meter from the pump assembly.
Work in progress.
Modified Cover box. Should look OK once painted and installed
