Cut out the firewall blanket before permanent attachment of the firewall. Started riveting the inside lower structural components that are easy to access while the lower skin is removed. I also preped for attachment of the engine stand to set the fuse on.
Cut out Firewall blanket
Started riveting these hard to access joints.
Installed the lower attach bolts as called out in the drawings.
