Rons Web Site
Date:  5-14-2007
Number of Hours:  8.00
Brief Description:  Fuse assembly - 3 - bad day
Needed to adjust the bends in the longerons to fit the skins. Turns out that I put an extra bend that was not needed. While straightening the bend, a crack developed in the longeron. Called vans and talked to them about two new ones. The shipping is the problem. It is 15' long and will be expensive to ship. Worked on several other small issues on the side skins.
