Ron Lendon's Aircraft Mfg.
Date:  4-5-2010
Number of Hours:  4.00
Brief Description:  Finally got that bolt in
Cut hole in bottom of fuselage to gain access to the flap torque tube. Unbloted the tube end to make accessibly easier. Now it was easy to push the bolt in the hole and close this one up.
Metal work mostly done till final assembly, passed the torch to Bob Mahieu for plumbing and wiring.
What I need is on the other side
Finally together
Finally together
Inspection panel
Inspection panel
