Brief Description: Getting left wing ready to close
Trimmed and attached L-Angles on left upper skin.
Finished framing and drilling box framework around the left wing aileron belcrank support. Riveted lower L-Angles and aileron support. Upper skin ready to reattach. Going to use wider hinge and trim the door of the wing lockers to accomadate the new upper wing spar angle.
Flipped wing and laid out the rivet line for the lower L-Angles for the wing skin.
Used laser line and tape to layout the holes for the rivet lines, much kinder to the paint.
Fuelube the fuel screen fittings and re-attached, both tanks back up on the rack..
