Ron Lendon's Aircraft Mfg.
Date:  1-26-2010
Number of Hours:  6.50
Brief Description:  Work Progress
Got the main spar ready to solid rivet the top flange. This will tie them together. Still need to place the outer uprights. If the holes can be duplicated easy that is the way I will go, easier than resetting it for placement in the fueslage.
Got started on the ailerons. The upgrade instructions for this piece did not come with the package.
6-zu-4.pdf was used for guidance.
