Ron Lendon's Aircraft Mfg.
CZAW CH601XL
6-ZU-2
Position and drill doublers on rear center spar we
Clean surface, layout center lines, positio and clamp parts.
Build up a wooden riser so I can clamp and work the parts better.
Using a pilot bushing to align 3/32 drill to the center of the exsisting holes in the web, spot face.
Remove the bushing and drill through. Did all A5 holes then used rivets to align the spar caps back in place.
Transfer punch centers and drill pilot holes using the drill press.
Re attach spar caps and open the 1/4 holes one drill size under and reamed them to final size.
CZAW CH601XL Home
2527
Zodiac CH 601 XL Home
