Brief Description: Finished shock brace and started seat.
Finished fitting the rear shock brace, held in place with magnets. Tacked then welded in place. Now the bike stands on it own kick stand.
Used torch heat to reshape the seat frame to confore to the fiberglass seat. Marked a dot where the seat post is and worked with that as a visual for location.
Rough cut 8" x 10" aluminum plate then annealed it using a 600 degree temp stick and water quenched it to soften it up.
