Brief Description: Made replacement pin for swing arm
The pin on the right is the new .015" larger diameter pin. Drilled and Tapped 12mm x 1.75mm hole, cut 6mm internal hex, drilled stop pin 1/16' that will be silversoldered in place, and hardened and drew out the pin on the right.
