Brief Description: Prep and weld main tube parts together
After welding the steering stem a .5" dia smooth rat tail file cleaned up the insides.
Welded the front wheel steering tube to the frame. I got it as close as I could and will be able to tie down both the front and rear axels to position the rear end true to the front axel.
Welded the bushing to the main tube then cleaned up the insides.
Cut and welded seat post upright. Welded seat post back rest adjuster tube to the upright.
