Ron Lendon's Aircraft Mfg.
Date:  1-10-2008
Number of Hours:  1.00
Brief Description:  Steering pivot and seat post holes
Used small dividers to mark 1/16 offset line from the 1/2" hole for the steering bushing. Used acorn burr to grind close to the line. Finished the hole size with fine cut 5/8 dia. rat tail file.
Layed out the 1" dia hole for the seat post and drilled and ground it out to fit.
