Brief Description: Fabricate the Rear Pivot Plates
Layed out the two Pivot Plates on some 3/16 thick 950XK Steel, didn't have any 4130 but this stuff will be more that tough enough for it's intended work. Setup the rotary table on the smithy to see how that process will work.
Center drilled then drilled a 3/8" hole then used a 4 flute 3/8" dia end mill and offset the cross-slide to make the hole size. Plunge cut around, every 2 cranks of the handle and left .015 for final clean-up. Offset .1" more and .05 deep to make the counter bore.
