Ron Lendon's Aircraft Mfg.
Date:  12-27-2007
Number of Hours:  1.00
Brief Description:  Prepare for welding
Layout and cut end for rear suspension pivot. Removed the bronze bushings from the pivot before welding. Clamped pivot in place and tack welded in place. Add some weld before forming the ends. Using heat, form ends around the pivot. Tack ends and hammer down the tacks before they cool to get a nice fit.
Cut away extra material
Read to form the ends
Tack the ends
Tack the ends
