Ron Lendon's Aircraft Mfg.
Light Sport Recumbent Bike
Cut Main Frame Tube
Used a variable speed sawsall and left the line on. Grind to split the line using 3" dia. 36 grit disk.
Used a 3" cut off wheel to finish and clear out the bottom of the cut, removed the line in that area.
Cut
Grind to split line
Finish the end of cut
CZAW CH601XL Home
144
196
Zodiac CH 601 XL Home
