Brief Description: Cut off ears and grind pedal crank
Beak tube ends back into shape then cut off the ears from the pedal crank housing. Without a metal band saw the best way I had was to use a vice, clamp, and a sawsall to remove the ears. Ground the bumps off to make it round again. Used rubber wheel to remove slits then face plate grinder to rough it in. Touched it up with 36 grit 3" disk then finished it off on the face plate with a bucket of water to keep it cool enough to hold.
This also helped get the crome off so the next weld job will be strong.
