Ron Lendon's Aircraft Mfg.
Light Sport Recumbent Bike
Prep Swing Arm and Idler Sprocket
Cleaned up and gave 1.75" dia shape to the swing arm. This will prep the area for welding to the pivot point.
Dissassembled the rear hub and cut the spokes to remove the hub.
These are the needed parts to make up the idler sproket. Much machining and welding to follow.
Cleaned and shaped
Needed parts from the rear hub
CZAW CH601XL Home
144
196
Zodiac CH 601 XL Home
