Ron Lendon's Aircraft Mfg.
Light Sport Recumbent Bike
Layout Main Frame Tube
Squared off one end and cleaned tube with lacquer thinner. Set tube in VeeBlocks and layed out the line lengths to the cuts using a 24" .01 graduated steel rule. Should be able to tip it up on a sinebar at 5 & 6 degrees and get the layout done.
The setup
Angle plate is on the rule
Scribing a line
CZAW CH601XL Home
144
196
Zodiac CH 601 XL Home
