Finished cutting the pedal crank from the rear frame. Used small fibre wheels to finish cutting where I could. Ground some of the pedal crank barrel to clean it up. Need to remove the ears to finish the clean up.
The rear tubes need to be tuned back out. Hammering collapsed the tubes slightly but it is all fixable.
