Finished up the machning for the drill guide .685" from center in both X & Y directions.
Made a template from the Grove Bracket to get the hole and pin locations. Talked to my Tech Rep and decided to place the calipers on the back side of the gear.
Marked the center and placed the template so minimal machining of the gear will be needed.
Lightly clamped drill guide and aligned the holes.
