Brief Description: Layout, cut, and bend air vents 4 of 5
Tried several ideas to make tube to hold duct tubing. Heres one from an L-Angle drilled about every 8-10 mm and split up the flange. Wrapped it around a 2" pvc pipe and stuck it through.
Think I can do better, off to Lowes Aircraft Supply.
