Went over to the airport today and scrounged around in Chuck Z's hanagar to find the other end of the flap cross fuselage rod. I had the long piece but missed the short one when I picked everything else up. Had to straighten out the plate a little but it should work just fine.
Setup switch locations and tested the flap motor again, works fine. The micro switches are getting replaced, cracked and bent.
Made and attached the rudder fairleads to the center wing spar
