Brief Description: Made shutter slides for steering rods
Saw this on the Matroncs photo share and thought it was a good idea for blocking the wind at the firewall steering rod slots. Basicly joggled the 28ga with .025 using a 1 ton arbor press, a couple of steel blocks and some tape.
Mounted to the firewall and the center sections slides real easy. I will leave the hole out till I get the gear made and figure out what the travel is.
