Used the shot bag and the flanging tool and hammer to flatten the part. Just gave it a couple of hits into the bag and it flattens out pretty good.
Then I went around each flange location and set the angle. The part is flat on the table and the protractor is parallel to the table. Each location is marked when correct, change angle 1.5 degrees then set the next one.
