Brief Description: Final fit of Rear Frame Channel
Set 3/4" plywood up on blocks and weights so I could clamp the flange of 6b5-2. Squared it up to the end of the bench and set the laser at the other end of the table in the center.
Lined up the parts and used the Attach Plate as a drill guide. Checked setup then drilled Silver, then Checked again. Drilled Copper, then Black clecoes.
