Ron Lendon's Aircraft Mfg.
Date:  12-6-2008
Number of Hours:  1.00
Manual Reference:  6-b-3
Brief Description:  Add L angles and other Z angles to bottom skin
I used a different sequence of events to mark the holes in these parts. Rather than trying to pull the line into the hole I just clecoed each end and marked through the skin. Removed the parts and center punched on the line all the marked holes. Then I clecoed everyother hole and ran the drill through each open hole, then moved all the clecoes over one hole and ran the drill through them. This took away any inaccuracies and made the job much easier. They are straight.
The last picture shows how far off the mark was but punching on the line then drilling it brought it into the right place when assembled.
