Thanks to Gary Ray and Gutter Guard this is a real nice clean way to hide the brake lines aonlg the rear edge of the main gear.
Find the tangent points on the gear and mark em. Cut gutter guard to fit between lines.
Tape brake line to gear, test fit gutter guard. To loose, so I jammed the gutter gard into the leaf brake and clamped the raduis smaller. Test fit, better.
Cut lower edge to 2" for gluing and marked the radius cut line so it would be tight and below the top surface of the main gear..
