Ron Lendon's Aircraft Mfg.
Date:  2-4-2011
Number of Hours:  1.50
Brief Description:  Shaping metal around front hoop
Removed front hoop and draw filed leading edge of the skin. Deburred and wiped it down real good with oily rag.
Prebent edge using small plastic hammer and a curved 3/4" T-Dolly from Fournier Enterprises. The object is to form the edge first so when your cleco it back together all you have to do is smooth out the leading edge a little bit.
Before
Before
After
After
