Brief Description: Layout New Points Plate for Dual Points
Used .062 4130 steel to make another plate to hold two point sets. I took the original points plate off, cut off the arm from the vacumn advance so I could lay it flat over the new center hole.
Clamped it all down and transfer punched the group of three holes.
Next cut it out, drill the hold down holes and center hole. I will position the new plate on the distributor base, tram in the bushing on a turntable and offset and rotate 180 degrees for each of the three holes for the point sets.
Need to make a punch set to create the recess for the point piviot point.
