Brief Description: Make fixture for exhaust manifold
Should have done this first. Forgot how much things move when welding.
Each tube joint area shrinks when the weld cools. There is now an arc along the bottom manifold wher it should be straight. I am goin to try to heat the manifold and get it to fit on this fixture.
You can see in the bottom picture, with the center tube lined up both outer tubes need to move out.
If that does not work I will cut the welds, fixture it and re-weld.
