Ron Lendon's Aircraft Mfg.
Date:  3-12-2010
Number of Hours:  2.50
Brief Description:  Make cardboard paint spray booth
Found good 1/16 drills in the machinists box downstairs and drilled the valve cover clamps for safety wire. Went over to the sand blast place and it has new owners, Brian did the parts for $35 and turned them out in a coupe of hours, had them back in my hands before lunch.
Drilled new valve cover bolts for safety wire.
While I was waiting I constructed this little spray booth from cardboard boxes packing tape and a furnace filter. With a couple of large boxes strategically cut, supports and gap filler were created and taped in place to hold the filter. 1 - 1/4 hole saw through the back and insert the shopvac hose. Works real good for keeping the overspray under control.
